set codes for keypad?
Not sure what you mean, do you need to know where to find the factory code. Or how to program it for a different code. if its to program for a different code, the instructions are in your owners manual. If you need to get the factory code. You have to remove the dash bezel and radio, the module is right behind the radio. It will have a label, with the code on it.
