1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
set codes for keypad?
Old 01-19-2009, 04:43 PM
jeffbdeleeuw's Avatar
jeffbdeleeuw
jeffbdeleeuw is offline
i have a 2005 f250 sd, i wanted to if anyone knows where to find the set code for the door keypad? I wanted to add another code to use daily.
thanks for the input.
Old 01-19-2009, 06:59 PM
motown's Avatar
motown
motown is offline
Not sure what you mean, do you need to know where to find the factory code. Or how to program it for a different code. if its to program for a different code, the instructions are in your owners manual. If you need to get the factory code. You have to remove the dash bezel and radio, the module is right behind the radio. It will have a label, with the code on it.
Old 01-19-2009, 07:52 PM
jeffbdeleeuw
Thanks bud!
