question about lights
I have been tossing the idea of putting some lights in the center of the front bumper. I would like to have it where they come on when i turn my lights on bright. So what all is involved in doing this. FYI: my truck is not equipped with the lower lights in the bumper.
You could add a relay that is operated (turned on/off) by the hi-beam switch (you'll have to get a wiring diagram or use a voltmeter/test light to find the wire that is charged/activated when you switch to brights) and tap in to your fuse box for power (I don't know how to wire in a new fuse - in the past I've just used an open spot for power and added an in-line fuse).
pretty easy. just need a relay and the lights
find the hot wire for when your high beams are on. then use a good "T" connector and run a wire to the relay. make sure to seal that connector up real good.
and mount the relay with the pins facing down...facing up collects water and will short it out.
check out the drawing below
like exactly how tylus drew. it's the most safest/reliable way
