08 Tire Pressure Light Ticks Me Off!
I hate the TPMS! I have not only the light but also the message center notification. My research indicates that the putting-all-the-sensors-in-the-spare trick does not work. I tried using the remote fob to retrain all tires to a lower pressure which also does not work. Has anyone figured out how to defeat this annoying feature yet? Are there any electronic programmers or tuners out there that have that capability?
I run 80 psi in my 08 king ranch and never have any trouble nor even knew is had a tpms. Run what ford recomends and u should have no problems unless a sensor is bad. U can't outsmart the trucks computer most of the time. Run cheap D or C load range and low preasure and the truck will let u know. Want to run 50 or 65 psi i think ford has a f150 or ranger for them there low presures.
For me, 80 psi, or even the 65 psi it takes to keep my TPMS light off, is too stiff for my liking. Even on my stock Contis, the rear tires were not even flat on the ground at 65 psi. FYI: My tires are E load range BFG and were not cheap. If you run 80 psi with no load, you are going to prematurely wear the center of your rear tires. I have seen it done.
That isn't his problem. It is the fact you cannot run the tires at a low enough pressure to get proper treadwear and traction with out tripping the TPMS. It is set at too high a pressure for most users. I like to run my rears at 48 to 50 psi when empty and I cannot do that as the TPMS is set to trip just a little below 65 psi.
