what style cam
Old 04-03-2010, 12:07 PM
IsoGrifo's Avatar
IsoGrifo
IsoGrifo is offline
what style cam
Just curious as to which cam you guys would use in a F/I 2.3, a hydraulic flat tappet, or hydraulic roller follower?
Old 04-07-2010, 05:22 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
The roller will not be affected by the low ZDDP levels in the oil. With the flat tappet I would recommend adding ZDDP with each oil change
Old 04-07-2010, 05:25 PM
mud bros's Avatar
mud bros
mud bros is offline
excelent tip!
go with the roller as the open close rates are much faster and allow for more duration without affecting mileage or drivabuility.
i would replace the valve springs with it also to a set from a roller cammed engine
Fmfl
02-08-2015 06:06 AM
68turquoise300I6
10-03-2014 11:00 AM
Shwan_89HD
10-04-2013 05:29 PM
Nally427
11-02-2012 09:01 PM
green1995
01-27-2010 03:33 AM
Quick Reply: what style cam
