what style cam
Just curious as to which cam you guys would use in a F/I 2.3, a hydraulic flat tappet, or hydraulic roller follower?
Originally Posted by IsoGrifo
(Post 8721863)
Originally Posted by Beechkid
(Post 8740790)
The roller will not be affected by the low ZDDP levels in the oil. With the flat tappet I would recommend adding ZDDP with each oil change
go with the roller as the open close rates are much faster and allow for more duration without affecting mileage or drivabuility. i would replace the valve springs with it also to a set from a roller cammed engine |
