New P codes today, wonder whats happening now
I got the SES light today, and pulled the codes off the truck. A couple I have seen before, but a few are new.
P0603
P1247
P1211
P0542
P0640
I know the last two are the air heater, so thats probably not a biggie, but the low turbo boost, and the keep alive memory are new though. Anyone have an idea on what is going on?
I looked at all the boots, etc for the boost problem, thought I may have had a leak there, and I cant find anything.
Thanks again guys!
P0603
P1247
P1211
P0542
P0640
Thanks again guys!
P0603 is from the Edge, so you can ignore it.
Also the P1211 code is extremely common when running a chip or tuner. If you suspect problems with the HPOP system (the IPR, ICP sensor, etc), switch to stock and see if you still get codes, or monitor with a scan tool.
As for the P1247, erase the code and see if it pops back up. That can be triggered under certain circumstances when you have a chip or tuner installed. If you don't notice any problems with boost or EGT's while driving, then it might be just a fluke code that popped up. If it continues to come up constantly, then you need to check for a problem.
