Default keypad code on 2005 F-150
Old 12-18-2008, 02:47 PM
Doovehead's Avatar
Doovehead
Doovehead is offline
Just purchased a used 05 FX4 and heard this is the place to come with advice and help on these pickups. I also have a friend whose looking for the default code on his 04 F-250
Can anyone tell me the location of the default keypad entry code on these pickups?
Thanks!
Old 12-18-2008, 02:49 PM
Flying_Dutchman's Avatar
Flying_Dutchman
Flying_Dutchman is offline
My code for my 06 was on a card inside my owners manual. Im not sure if they print it somewhere on the vehicle itself.
Old 12-18-2008, 02:51 PM
Doovehead's Avatar
Doovehead
Yeah this is where I originally looked but the card was missing. I also purchased the vehicle used... I did a quick search before posting and a few users said it was behind the seats or under the dash. I wouldn't mind some direction or even an exact location before I tear the vehicle apart looking for the damn thing.
Old 12-18-2008, 02:56 PM
SteveVFX4's Avatar
SteveVFX4
SteveVFX4 is offline
I thought it's indicated on the BCM (body control module) which is mounted on the back inside of the cab on the passenger side?
Old 12-18-2008, 03:48 PM
Doovehead's Avatar
Doovehead
Would that be behind the rear passenger seat? If that's the case it's not there... The travis method was a !@#$...
Old 12-18-2008, 03:59 PM
SteveVFX4's Avatar
SteveVFX4
^yeah, that's what I meant to say, behind the panel behind the rear passenger seat if you got a supercab or supercrew truck.
at least that's what I read on here. I have my code because I bought my truck new.
Old 12-18-2008, 04:35 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
the box is on the driver side behind the rear seat ...theirs two bolt and clips that hold the seat on ...do a search on the fourm and you can find pics and a better how to do
Old 12-18-2008, 07:41 PM
SteveVFX4's Avatar
SteveVFX4
oops, yeah it is on the rear driver's side. Here is some info from a member's old post:
I found the code (with some help from my neighbor). It is behind the plastic trim that is in the rear corner on the driver's side of the cab. Down near the floor. Remove the door seal and pull the plastic trim away from the truck sheet metal. You might have to take off some more nearby trim to see better. With a flash light I could see the 5 digits, they were even right side up when looking from the outside. The numbers were on the right side (towards the tail gate) about in the middle of the computer. The computer has the word Siemans on it.
johnzenobia
2009 - 2014 F150
04-27-2015 11:16 AM
danlee
09-02-2009 08:11 PM
SNOW F-150
2004 - 2008 F150
06-24-2009 11:58 AM
3KIDDAD
01-17-2007 09:13 PM
excursion2001
General Automotive Discussion
02-09-2004 10:10 AM
Quick Reply: Default keypad code on 2005 F-150
