Transmission lines 1990 f250
Hello all. I'm sitting here at work frustrated because I'm not sure what to get for parts on my way home. We have a storm coming tomorrow, so I thought it would be a good idea to drive my plow truck to work with me today to be sure all was well. I started it, let it warm up and went to drive off to work and it didn't move. After checking it quickly, the transmission cooling lines appear to have sprung a leak. I couldn't be late for work, but I looked quick and they seem to be 5/16, is this correct? My other question is, I have no idea how much pressure is in the cooling lines. Can these be patched with rubber hose and clamps, or do I need to get steel tubing and brass ferrules and such to keep them rigid metal lines? Thank you in advance for your help.
Jay
Jay
5/16 sounds right but don't quote me on that. I had a F150 with an AOD anyway. I noticed my cooler lines were spliced from the factory using a compression fittings so I just replaced the rusted out section with a length of tubing and two compression fittings. Rather simple if you have room to fit two wrenches in there. This repair held fine for two years until I swapped out my sloshbox for a ZF five speed
Jay
Jay
I lost all tranny fluid in minutes when PO rubber line pushed off of metal line coming from front pump. I cruised to a slow slipping halt. If you use rubber; then flare ends of metal lines to help clamps hold tight. I replaced mine with 5/16 compression fittings and section of metal line.
Thank you all for your help.
Just an update. I bent new steel lines, but I too had short rubber connections just below the cooler. I took a minute to put a slight flare on the end of the steel lines before sliding the rubber over them and everything has been holding up just fine. I'm not so sure I would still consider using an entire length of rubber though. It really didn't take me all that long to bend up new steel lines, and I also have since noticed, LMC has prebent lines available.
Jay
Jay
