Whats the biggest windshield wiper you can fit on the X
Old 12-08-2008, 07:54 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
Title says it all whats the biggest size wiper you can fit on the front and back of the X.
Thanks
Nick
Old 12-08-2008, 08:02 PM
dsquared's Avatar
dsquared
dsquared is offline
I know I've seen posted in here 24" for the front. The rear, don't know...
Old 12-08-2008, 08:05 PM
ramblemutt's Avatar
ramblemutt
ramblemutt is offline
Nor am I sure about the rear, but I have Bosch 24" on the front.
Old 12-08-2008, 10:21 PM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
I run 24" on both front wipers and recommend staying with the OEM size on the rear (which I think is 15")?
Why stay with OEM on rear... the larger size will not properly clean from top to bottom due to the longer length. I tried and went back to the OEM smaller size.
However, using 24's on the front works great!!!!
Old 12-08-2008, 11:31 PM
weekendwarriorfsw32
Master of Strokes
Thanks guys I did 24 on front and stock on back!
Old 12-30-2009, 05:40 PM
Coolstrategist's Avatar
Coolstrategist
Coolstrategist is offline
Has anybody ever run a 28" on the front?
I have been running 26" Bosch Icon with great success the last two years. Advance Auto has a $10 off $25 coupon and $8 off two Bosch Icon blades right now. My two local stores only have 20" and 28" left.
When I put the 28" inch to the window it looked like it could work.
Don't want to miss the good deal.
Sales ends tomorrow.
Old 12-30-2009, 08:18 PM
CanadianSmokie's Avatar
CanadianSmokie
CanadianSmokie is offline
I don't know if this would be an issue but the longer the blade the more friction created, possibly causing damage to the wiper motor and/or linkage.
My wiper assembly/linkage is really loose (like that since I got it) which causes the wipers to not make proper contact, no matter what blade I use. Will be trying to locate a good one out of a salvage yard when the weather gets a bit better.
Old 12-31-2009, 10:21 AM
katiesdad7's Avatar
katiesdad7
katiesdad7 is offline
I did the 24s on the front and its the way to go. Any bigger and you start hitting trim.
Old 01-04-2010, 05:26 PM
bigsnyder's Avatar
bigsnyder
bigsnyder is offline
Running 24"s in the front and an 18" on the rear. Works great.
Old 01-04-2010, 06:12 PM
joetech's Avatar
joetech
joetech is offline
I tried 26's on the front and have some cleaning issues. I am going back to the 24's soon.
Joe
Old 01-05-2010, 12:25 PM
mohrds's Avatar
mohrds
mohrds is offline
I run 26" on the driver's side, 24" on the passenger and 18" on the rear.
I run the Michelin Symphony Wiper blades. Available at Wal-Mart. The only "Bosch Icon" style blades I've found that you can use refills with saving big $$$
Doug
Old 12-02-2011, 03:05 PM
aklim's Avatar
aklim
aklim is offline
Doug
I am using the 26 and 24 Bosch Icons for the front but on the rear, the 18 inch blade collides with my rear glass wiper washer outlet
Old 12-02-2011, 08:56 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
24s on the front and stock rear here. but i need a new rear one soon.
Old 12-02-2011, 09:15 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Right now i'm running stock size but I also recommend putting RAIN X on the windshield. That stuff works GREAT for shedding water.
Old 12-02-2011, 11:29 PM
G550_Capt's Avatar
G550_Capt
G550_Capt is offline
X2 what Rob said. Rain-X with 24" front, OEM rear.
Quick Reply: Whats the biggest windshield wiper you can fit on the X
