Whats the biggest windshield wiper you can fit on the X
I run 24" on both front wipers and recommend staying with the OEM size on the rear (which I think is 15")?
Why stay with OEM on rear... the larger size will not properly clean from top to bottom due to the longer length. I tried and went back to the OEM smaller size.
However, using 24's on the front works great!!!!
Has anybody ever run a 28" on the front?
I have been running 26" Bosch Icon with great success the last two years. Advance Auto has a $10 off $25 coupon and $8 off two Bosch Icon blades right now. My two local stores only have 20" and 28" left.
When I put the 28" inch to the window it looked like it could work.
Don't want to miss the good deal.
Sales ends tomorrow.
I don't know if this would be an issue but the longer the blade the more friction created, possibly causing damage to the wiper motor and/or linkage.
My wiper assembly/linkage is really loose (like that since I got it) which causes the wipers to not make proper contact, no matter what blade I use. Will be trying to locate a good one out of a salvage yard when the weather gets a bit better.
I am using the 26 and 24 Bosch Icons for the front but on the rear, the 18 inch blade collides with my rear glass wiper washer outlet
