1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 f350 rims 8 on 6.5 inch rims
Old 12-01-2008, 12:59 AM
robjs111's Avatar
robjs111
robjs111 is offline
can anybody tell me if ford used the same bolt pattern, 8 on 170 since the early 80's on all the f250 and f350?? have a set of older early 90's rims that i want to use for winter and they are 8 on 6.5 i believe and my truck is a 2001 f350. thanks.
Old 12-01-2008, 07:29 AM
Pocket's Avatar
Pocket
Pocket is offline
No, the 8x170 bolt pattern was used exclusively on Superduties beginning in 1999 to the present. The 8x6.5 rims will not fit your truck, and rims off your 01 F-350 will not fit older Fords.
Old 12-01-2008, 05:36 PM
robjs111's Avatar
robjs111
robjs111 is offline
can the 6.5 in bolt holes be drilled out a mm to equal 170 mm?? thanks.
Old 12-01-2008, 05:59 PM
laka's Avatar
laka
laka is offline
6.5" is only 165mm. You would have to drill the holes at least 10mm bigger for the studs to fit through. The lug nuts probably wouldnt seat properly. Probably not a good idea.
Old 12-01-2008, 08:28 PM
Pocket's Avatar
Pocket
Pocket is offline
On top of what Laka said, you also have to consider that Superduty wheels are hub centric, the OBS trucks are lug centric. You won't be able to use the stock Superduty lug nuts to secure that wheel, assuming you were able to sucessfully drill out the mounting holes (which is something that most people would not recommend). So you would in essence have to go out and buy a new set of lug nuts that would fit the thread pitch, and would be compatible with lug centric wheels.
dhglaser
09-25-2023 04:54 PM
Genesis
01-23-2022 07:07 AM
sobz
02-08-2015 11:52 AM
Firebird racer
11-17-2014 09:50 PM
Hdlinerman
12-05-1999 11:22 AM
Quick Reply: 2001 f350 rims 8 on 6.5 inch rims
