1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Coolant antifreeze leak 6.0 diesel.
Old 11-27-2008, 11:33 PM
TDITCH's Avatar
TDITCH
TDITCH is offline
'05 F-350 6.0 diesel, auto trans, 42,259 miles, rarely pulls a trailer or a load, stock and in very good condition. I bought this truck new Nov. '04. Todays date, 27 Nov. 2008. Now my first and only problem. I noticed on 25 Nov. 2008 that I have a large puddle of coolant under the truck. Only when the engine is totally cold does it leak golden colored antifreeze running down from what appears to be at the cylinder head gaskets at lower rear corners on both sides of the engine. My drive way is a slightly sloped black top and now with a stream of coolant running more than 30 feet out with a puddle the width of the truck under neath. The right side above the starter leaks much more than the left, a constant drip. 26 Nov. 2008 After adding one gallon of coolant mix up to the cold mark, I go to the selling dealer for this problem and an oil change and fluids check. The invoice tells me they replaced a hose clamp part number B7A*8287*AA, changed the oil and filter, performed the multi point inspection noting all fluids are full, that I have a week battery and one front tire may require future attention. I paid the 149 dollar and 50 cents bill and drove 7 miles home. Next day, today 27 Nov. 2008 my neighbor and his friend comes over to tell me they noticed antifreeze leaking from under my truck. At this point I will not mention to what agency in Ann Arbor, Mi. his friend works for but I will say that he was very concerned. Photos and a video have been taken. I raised the hood, looked around, found no leaks anywhere, nothing wet, power steering fluid still below the add mark, dark engine oil and a constant drip mess of coolant in my drive way coming from the same places as mentioned above. In the morning 28 Nov. 2008 I'll return to the Belleville, Mi. dealer to try once again to get this matter taken care of. Comments from any one?
Old 11-28-2008, 10:17 AM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Powerstroke_wannabe is offline
Sounds like it may be the coolant line going into your EGR cooler.
jonrjen
6.7L Power Stroke Diesel
08-05-2015 05:54 PM
Laner
6.4L Power Stroke Diesel
20
07-07-2014 09:14 PM
DesertStorm
06-22-2012 08:10 PM
06NEWTOME
02-06-2011 08:55 AM
Moto7387
1997 - 2003 F150
05-01-2010 08:50 AM
Quick Reply: Coolant antifreeze leak 6.0 diesel.
