1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Strange inside-edge tire wear.
Old 11-26-2008, 11:28 PM
natewoz's Avatar
natewoz
natewoz is offline
My truck has been producing some strange tire wear on the the inside edges of the front tires. It is not typical toe-in wear camber wear. It is a cupping type wear that shows up on the inside 1.5" of the tread. I am running BFG AT/KO 235/85r16 at 80 psi on factory wheels. On the inside edge, one lug will be normal height and the next will be 3/32 or so shorter than the rest of the tire and alternates every-other lug all the way around the circumference of the tire. Wear is visibly noticeable after about 5k miles.
I am a bit stumped. Ball joints are good, they are tight and were replaced 39K ago. Steering linkage is tight and in good condition, and the steering box is properly adjusted. My shocks are factory originals, well due for replacement now after 128k miles.
Any input would be greatly appreciated. Thanks
Old 11-27-2008, 07:31 AM
Angrywasp's Avatar
Angrywasp
Angrywasp is offline
It is probably an alignment issue. I've seen it on jeep forums but can't remember exactly what caused/fixed it although it was normally associated with a lifted vehicle/larger tires.
Old 11-27-2008, 09:48 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
That can be typical toe out wear on a bfg. because the lugs are so square adjacent tread lugs wear differently, instead of feathering. I've seen it before on open block/shoulder tires. Is it the same on both sides?
Old 11-27-2008, 10:51 AM
natewoz's Avatar
natewoz
natewoz is offline
aldridgec, They are the same on both sides. The wear on the worn lugs has a concave radius shape to it.
I also found the typo in my first post, I meant toe-out, not toe-in.
Thanks guys!
Old 11-27-2008, 01:41 PM
aldridgec's Avatar
aldridgec
Yeah, I would still vote it is toe'd out. BFG AT's are funny like that.
Old 11-27-2008, 03:01 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
could also be balance,shocks or tire pressure related
Old 11-27-2008, 05:26 PM
MassSupra's Avatar
MassSupra
MassSupra is offline
Replace those shocks and rebalance the tires. It may not go away but it will keep them from getting worse. Chopping in the rear is usually a worn shock indication.
Old 11-27-2008, 06:00 PM
Toyman's Avatar
Toyman
Toyman is offline
Check your front bearings also. Ijust replaced everything on my front axle, the tires were wearing just as yours are. The bearings were wasted, left tire moved about an inch at the top.
Toyman
Old 11-27-2008, 07:01 PM
maadman's Avatar
maadman
maadman is offline
Any inside wear indicates alignment trouble. Have it realigned by a reputable company experienced with larger vehicles. I'm curious as to why you are running 80 lbs in the front. I only run 55 on mine and have not had any problems.
Old 11-27-2008, 08:31 PM
aldridgec's Avatar
aldridgec
The bearings are a good idea too, somehow assumed they were checked. Loose bearings can cause the wheel to wobble around. Unlike bad ball joints which would have a similar effect of allowing the tire to tilt in at the top, when brakes are applied the forces work differently on the tire which can cause some odd wear patterns if bad enough.
Old 11-27-2008, 10:02 PM
natewoz's Avatar
natewoz
natewoz is offline
I'll have the truck on the lift tomorrow to fix stuck caliper slides on the driver side front, so I'll check the bearings and double check everything else for play while I'm at it. If all is good, the truck will be off to the dealer for an alignment.... I sure do miss having the use of a brand new Hunter rack.
I run 80 psi all the way around because the truck gets loaded up on a very regular basis, and this time of year it has 160# of winch and mount hanging on the front too. The tires run flat against the road and don't wear any extra, I get a little better mileage, and I also don't mind a firm ride.
I'm trying to make up my mind on doing a small lift before I buy shocks, I should probably make it up soon.
Thanks again
Old 11-28-2008, 01:21 AM
Raining111's Avatar
Raining111
Raining111 is offline
The wheel might have gone out of balance. Happened on two of my BFGs as well, showed up as hi/low tread wear along the center of the tires.
Old 11-28-2008, 11:45 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like toe-out if both tires are the same...
Old 07-19-2014, 10:23 PM
Noman's Avatar
Noman
Noman is offline
I am having the same problem on my 2003 F350 LE super duty 4x4. This is the third set of front tires that have worn on both the inside and the outside. The center of the tires are almost like new when the inside and outside are nearly worn through.
I run 90 PSI in them or they look half flat. I think it is the weight of the diesel engine that puts so much weight on them. I tried 50 lbs an went through a set of tires in 7,000 miles. With 90 PSI I get about 12K.
The wear starts with evey other lug both inside and outside and only about 1.5 inches in. Then within about 10,000 miles the tires are gone. I have had it aligned twice with no help from it. I am now looking at replacing most of the front end joints.
Old 07-20-2014, 10:42 AM
railroader's Avatar
railroader
railroader is offline
I had similar cupping and wear like you mentioned. When my alignment guy looked at it
he replaced that bushing on top on the left side and cross rotated the tires. He said to
drive it a hundred or so miles and the noise should go away. It did! Mine came with Cooper
off road tires and will be getting replaced before long with something for the highway.
Quick Reply: Strange inside-edge tire wear.
