Key Out, Still Chimes
Hi All, Just bought an 05 F-350, problem is even when the key is out, it still chimes and the auto-unlock feature still activates, i have done several different searches and even tried pulling out the ignition and covering the contacts with tape, but it still does same thing, not sure if whole ignition is maybe faulty, any one else have this problem? Thanks
12volts yellow (30A), lt grn/pur (30A) + ignition harness
Starter dk. green + ignition harness
Second Starter N/A
Ignition red/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow and red/black + ignition harness
Second Accessory dk. blue/lt. green + ignition harness
Keysense black/pink - ignition harness
Power Lock pink/yellow (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the lock wire is white/red (-), in the driver kick, door harness or also at the VSM, gray plug, pin 3.
The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Notes: Vehicles with keyless entry, the unlock wire is black/white (-), in the driver kick, door harness or also at the VSM, gray plug, pin 2.
Vehicles with keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor red/orange 5wi driver kick or VSM, gray plug, pin 7
Parking Lights+ brown + switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + back of fuse box, black 8 pin plug
Door Trigger use dome supervision wire
Dome Supervision black/lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt green or red/yellow ac any ignition coil or fuel injector
Notes: On diesel vehicles the tach wire is lt. green/white in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - switch or cluster, blue plug, pin 18
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
You can try cutting the keysense wire to eliminate the lock cylinder, if it still dings then you have an issue with the databus or body module.
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Trunk/Hatch Pin N/A
Hood Pin N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Notes:
Received 3,113 Likes
on
it took me 3 months of head scratching to fix this exact problem on a 97 F150..
the multi function switch was bad.i did the whole key cylinder thing, even went as far as putting all new parts in the cylinder housing. still chimed. then the wipers would not park one day.
i put a new MFS in, and the chiming stopped working when it was not supposed to.
Mine has the same problem in my 04 F250, get key chime and auto-unlock when key is out, if i move the ignition cylinder the chime stops.. On the other hand sometimes i do not get a key chime with the key in the ignition. Dose not sound like you have the same problem, i think i have loose or bad contacts on the Key sense part of the ingnition cylinder.
I have an '05 F-250 that was doing the same. I pulled out the cyllinder and their was a piece broken that is the ground that comes in contact with the key. I simply cut the wire and no more dinging. The auto unlock still occurs however, but I don't lock it from the inside, I use either my keypad or key fob.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-05-2016 05:09 PM
