94 f250 4x4 needs front axle
Old 11-12-2008, 04:24 PM
palmer1155's Avatar
palmer1155
palmer1155 is offline
Ok i have a 1994 f250 4x4 7.3 diesel turbo (not a powerstroke). I was in a wreck and trashed the pasenger side of the independent front axle. I need the pasenger side IFS, drag link, and a steering box. Am i better off to fix this axle or do a straight axle. Any help is greatly appreciated!!
Thanks
Old 11-12-2008, 05:02 PM
guitarnik's Avatar
guitarnik
guitarnik is offline
go with a one ton straight axle, much better and longer lasting.
Old 11-12-2008, 05:07 PM
palmer1155's Avatar
palmer1155
How hard is the conversion to straight axle? Will everything bolt up directly or is some modification required?
Old 11-12-2008, 05:43 PM
andym's Avatar
andym
andym is offline
Since you already have a leaf-sprung front axle, a swap to a solid Dana 60 is pretty straightforward. The axle alone will set you back quite a bit, though. On the other hand, you could pick the parts from a junkyard for a lot less. Unless you plan on putting big tires or doing serious offroading with the truck, a solid axle is probably overkill. There are millions of TTB F-250's out there that have endured years of abuse and still work just fine.
Old 11-12-2008, 05:48 PM
guitarnik's Avatar
guitarnik
yeah now that i think of it, like andym said solid is probably i little over kill unless its reeeaaaly gooing to be abused. and it would a heck of lot cheaper to just replace half of yours.
Old 11-12-2008, 05:55 PM
palmer1155's Avatar
palmer1155
Where can i find the parts, i have checked the local junkyards and have found zilch!
Old 11-12-2008, 05:57 PM
andym's Avatar
andym
andym is offline
Sounds like you need to go to a better junkyard. The one I go to I could have the parts out of about 10 different trucks. I'd have to pull them myself, but you save a ton of money that way.
Old 11-18-2008, 02:43 PM
palmer1155's Avatar
palmer1155
I have found all of the parts that i need except for one. It is the piece that runs from the front differential out to the wheel( CV type axle runs through it). Can anyone tell me where I can buy one new or used online, I cannot find one anywhere in my local junkyards. Help please!!!
Old 11-18-2008, 07:17 PM
andym's Avatar
andym
andym is offline
Can you be more specific? Axle stub shaft? Axle shaft? Spindle?
drquest65
37
02-10-2017 08:11 AM
DillonZ81ford
07-30-2016 06:55 PM
tyhorn26
1999 to 2016 Super Duty
06-21-2015 02:45 PM
jawdoc
Modular V10 (6.8l)
08-17-2014 11:48 AM
hmbldr56
1997-2006 Expedition & Navigator
05-12-2011 05:19 PM
Quick Reply: 94 f250 4x4 needs front axle
