Restoring the Aluminum Trim
May want to check w/ local plating shops and get a quote, est. on having the 65 grille anodized few yrs. ago was around $400. Ended up purchasing the anodize stripper, the grille originally came off a construction truck and had a few dings so ended up working out the dings then started out with med. fine sandpaper and worked up to ultra-fine, then polished. With the smaller items ended up using a buffer. Decided to use an aerosol can of clear so I would not have to spend time keeping it polished, there are number of alum clear coats available, last checked Eastwood have couple products. Without the anodize the alum can turn color in relatively short period of time. Next time will check into cost of having pieces powder coated, or do it myself, that's if they make a clear.
If you were to run a search and narrow field to 61-66 forum should find additional info including pic member submitted of the grille he did using a can of alum. paint, must admit, from the pic did not look bad.
Have read where a guy used Prematex aersol gasket remover product,( Autozone 8 bucks for a 4oz can ooch) havn't try it yet but will this winter on my 78 grille, its not as damaged as the old trim on my 65 model so hopefully I can repolish it & then just protect with a clear coat type product.
Mitch
Mitch
smittysan
27
06-30-2014 10:00 PM
PRUSue
05-28-2012 03:47 PM
Diesel_Brad
75
12-18-2009 07:11 PM
