Tips on Engine removal F600 or N600-1964
I am trying to pull the engine from the transmission and it seems that I can not go any further than approx. 1". I guess it is binding somewhere on the transmission shaft.
Any tips?
I have tried to pull it apart with a pry bar on top, but not on bottom?
Do I need to hold up the transmission's bell housing even though the transmission has side mounts?
Should I use an engine leveler?
Or???
Let me know and thank you for all and any info!
Any tips?
Or???
I have tried to pull it apart with a pry bar on top, but not on bottom? Do I need to hold up the transmission's bell housing even though the transmission has side mounts? Should I use an engine leveler?
Most members of this forum have F100/350 pickups. F100/350's use different V8 engines than 500 and larger series trucks.
breezesboy
03-16-2015 05:36 PM
WoomaHodal
06-24-2005 12:18 PM
94rangerprerunner
4 Cylinder Engines
12-13-2003 08:12 AM
