f600 engine pull help
Old Sep 24, 2006 | 07:11 PM
jetfixer's Avatar
jetfixer
Ok, so I have a 72 f600 that I have to pull the engine. My problem, it's been so long since I have pulled an engine and the last time was little ranger with an auto in it. I am pulling a 330 attached to a five speed tranny. I thought I had everything ready but I cant get the engine out. I have 4 bolts attaching the engine to bell housing pulled and the motor mount off. What am I missing?
Old Sep 24, 2006 | 08:24 PM
Ricke9590's Avatar
Ricke9590
Have you seprated the tranny and engine? The input shaft from the tranny to the engine can be a serious PITA on any 5 speed.
Old Sep 24, 2006 | 08:55 PM
jetfixer's Avatar
jetfixer
No, that's where the problem is I think, any tips from anyone ?
Old Sep 24, 2006 | 09:22 PM
Gary B's Avatar
Gary B
if you mean that you removed four engine attaching bolts from the bell housing then you still have two more to remove, look closely.
Old Sep 24, 2006 | 10:11 PM
jetfixer's Avatar
jetfixer
Thanks for the tip, I will look for them tomorrow. I have 4 along the top side where are the other 2 ?
Old Sep 25, 2006 | 11:10 AM
Gary B's Avatar
Gary B
down low on each side. one near starter hole and other ,oposite side,same position.
Old Sep 26, 2006 | 12:07 AM
jetfixer's Avatar
jetfixer
Gary, big thanks. I went out at midnight armed with a flashlight and flatblade screwdriver and removed 30+ years of oil and dirt on the bell housing and found the two other bolts. Thanks again!!!
Old Sep 26, 2006 | 08:43 AM
Gary B's Avatar
Gary B
glad to be of help, Gary
