Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-10-2008, 03:40 PM
07EXPYEL 07EXPYEL is offline
Garage is empty, add now
07EXPYEL is starting off with a positive reputation.
2009 adds TOW/HAUL Switch
Found this at the ford fleet site:
http://www.motorcraftservice.com/pub.../09exdog1e.pdf
What are the chances of a computer re-flash to add the functionality? The push button would be another issue. The TOW/HAUL selection is deisplayed on the drivers LED display.
quote:
Tow/Haul delays upshifts to reduce frequency of transmission shifting.
Tow/Haul also provides engine braking in all forward gears when the
transmission is in the D (Overdrive) position; this engine braking will
slow the vehicle and assist the driver in controlling the vehicle when
descending a grade. Depending on driving conditions and load
conditions, the transmission may downshift, slow the vehicle and control
the vehicle speed when descending a hill, without the accelerator pedal
being pressed. The amount of downshift braking provided will vary based
upon the amount the brake pedal is depressed.
To deactivate the Tow/Haul feature and return to normal driving mode,
press the button on the end of the gearshift lever. The TOW HAUL light
will no longer be illuminated.
When you shut-off and restart the engine, the transmission will
automatically return to normal D (Overdrive) mode (Tow/Haul OFF).
WARNING:
Do not use the Tow/Haul feature when driving in icy
or slippery conditions as the increased engine braking can cause
the rear wheels to slide and the vehicle to swing around with the
possible loss of vehicle control.
  #2 (permalink)
Old 11-10-2008, 05:30 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
yes but they've also changed the transmission to the 80 series up from the 75. It should also be noted that this transmission now carries similar shift stratigies as the F-150 but holds almost 3 quarts less then the F-150 (about 23% LESS if my math is right off the top of my head).
  #3 (permalink)
Old 11-10-2008, 11:31 PM
rich93cw rich93cw is offline
rich93cw is starting off with a positive reputation.
My 2007 tows just fine! Although it would be nice to have the ASC also apply the trailer brakes as the Explorer does.
Tags
2007, 2008, 2009, 2010, button, expedition, expedtion, f250, ford, haul, lincoln, navigator, switch, tow, towhaul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
