stock 460 carb
#31
#32
The secondaries pull up from vacuum created in the primary venturi's, thats between the "neck down" at the air horns and the butterflies. It works just like one of those vacuum "pumps" in the air conditioning catalogs that use an air compressor blowing over a small port thereby creating a vacuum in that port. The faster the air (venturi) moves over the hole, the more vacuum it creats. Thats why with even "0" manifold vacuum you have vacuum at the secondary opening diaphram.
It's the velocity of the air the engine sucks in through the venturi that creates the vacuum that opens the secondaries!!
You'll pardon my AH HAH! moment. Sometimes the most simple ideas can be the hardest to grasp. I now think I totally understand it .... or at least got a darn good grip on the concept. I now also see why vacuum secondaries can be so much better than mechanical ones in most street applications. I get "the springs" now too.
meangene21
01-05-2011 03:42 PM
powerstroker100
11-23-2010 04:54 AM
Raptor119
20
08-11-2009 06:24 PM
jdon88
02-08-2009 05:27 PM
87carbed
12-15-2004 07:28 AM
