transfer case and rear end fluid
I would recomend changing those fluids. The axles front and rear I used M1 70-140 synthetic. In the rear if you have limited slip you will also need the friction modifier. I bought mine at the Ford dealer, its like 8 oz I think. In the transfer case most on here use the same as your transmition would use, but when I changed mine last the fluid in the tansfer case was burnt, or starting to smell bad any way so I went with M1 transmition fluid to give it a little extra protection.
joewaldner
07-22-2010 10:05 PM
danlee
10-21-2009 06:45 AM
ccfdsuperduty
07-29-2007 08:17 PM
