351 w cam question?
351 w cam question?
Sorry I should have put this in my other post I am in the learning process. My truck is an 82 ford f150 xlt lariat supercab. I have a 351w non H.O. I have been saving money to put in the engine I want to put a four barrel carb intake cam and headers and eventually a set of gt 40 heads that I want to try to port myself. Now this truck is by no means a daily driver it barelly passes inspection. My weakness comes when it comes to cams I want to try to gain more torque the cam that is in it now i'm sure is stock and offers little. I have heard that that the xtreme 4x4 cams are good please give me some insight. Also don't have the heads yet so they will go on later. thanks in advance!
on
Check out the Edelbrock top end kit for these motors, that's essentially what you want to produce a broad powerband. The more you improve the engine breathing the more power it will make everywhere, the stock heads are really restrictive so there's nowhere to go but up. BTW there is no rev limiter on the stock ignition system as far as I know, an MSD system would be a good addition.
IMHO the two top cam builders are Iskenderian, Crane, Sig Erson and Crower (in that order IMHO). (fyi, the 3rd cam ed Isky ground in the garage of his house went in my dads engine!) With regards to lifters, isky is the only mfg that test every spring befor it leaves the shop.....a very, very important item.
Anyway, their techs will speak with you over the phone and provide recommendations based on your specific needs, but would recommend Isky & Crane as the primary. IMHO, while I'm not a big edelbrock fan, I highly recommend the air gap manifolds- requires little hand finishing and the flow is absolutely excellent- better than almost any other manifold on the market right out of the box no matter what the application- for both hp and tq.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
Ford Distributors
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/...d_351W_V8.html
Ford Distributors
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
GrossPapi
21
09-04-2013 09:06 AM
