10k mod question
Old 11-01-2008, 11:33 PM
cajunspice's Avatar
cajunspice
cajunspice is offline
10k mod question
I do not have green and red wires like the picture. Can I use the beige and red wire it is the mouth of the smiley face in the picture?
Old 11-02-2008, 12:20 AM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Welcome to
You want the blue/red wire. I had to peel back the tape about an inch to get a good look at the wire colors.
Old 11-02-2008, 08:58 AM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
what year is your truck?
if the colors are different then just go by the picture....
Old 11-02-2008, 10:04 AM
cajunspice's Avatar
cajunspice
its a 95 f350 auto
Old 11-02-2008, 09:35 PM
parrisw's Avatar
parrisw
parrisw is offline
What does the 10K mod do?
Old 11-02-2008, 09:51 PM
IDMooseMan's Avatar
IDMooseMan
We're tricking the PCM into thinking the HPOP pressure is low, so the PCM increases the HPOP pressure during the fuel injection cycle. This helps introduce fuel into the cylinders faster during each cycle.
Do a search for "ICP Resistance Mod Results" and you can see what the different resistors did for my horsepower and torque readings on a DynoJet chassis dyno.
I'm currently monitoring MPG changes using each resistor.
Old 11-02-2008, 11:05 PM
parrisw's Avatar
parrisw
parrisw is offline
Thanks man. I'll check it out.
GregAlex47
Aerostar
11-11-2014 08:19 PM
Talyn
06-03-2010 04:35 PM
cobrarep
09-02-2008 11:55 PM
cobrarep
1999 to 2016 Super Duty
24
09-02-2008 07:50 PM
XHunter
03-19-2007 01:28 PM
Quick Reply: 10k mod question
