gas mileage???
gas mileage???
i have a 1997 ford f-150 4x4 auto reg cab short bed... i am getting around 13 mile to the gallon is this about normal??? that is mostly highway driving at around 65 miles an hour... i had a 700 grizzly in the bed a treestand and a box on the rack with all of my clothes etc... prolly around 1100 pound in the bed... so is that pretty good given what i was hauling???
Mileage depends a lot on over all gearing. Are they stock sized tires? Once you go to bigger tires, mileage usually drops. Also, what gears are in it? I've noticed different gears have different sweet spots. And if you've changed tire sizes, that sweet spot changes.
I have stock tires on my 03 Screw, 17", and 3.73 rear end. Sweet spot on mine is about 63-65. I can get up to 18 with no winds. More typical (because it's always windy) is 16.5 to maybe 17. At 75, it'll be flat 16. All of these no loads.
I have a 3500 lbs pop up camper. I'll run 60-65 with that. I get usually 13-14mpg.
Also realize, the newer trucks have the PI heads in them. So that might help mileage a bit. That and I think the 4.6 just has to work harder than the 5.4 given the same conditions. So the sweet spot on the 4.6 is probably 55 or so.
There are just so many variables to mileage. Best you can do is keep up the maintenance, and keep the foot off the gas.
My dad had a 97 4.6L Ext cab Off Road Package, all stock and would get 19-20, not loaded with anything.
I have a 02 Ext Cab FX4 5.4L with 35s and 4.56gears (effective ratio 4.10) and get 14mpg just city driving. Last highway trip got 16.5 running 70-75mph.
