Failed Inspection!
Failed Inspection!
So I just had my truck inspected and it failed because of the lug nuts that were on it. I have the aluminum alcoa's from factory and the lug nuts are just standard steel tapered. They said they were the wrong kind for aluminum wheel and were unsafe cause they could back out, and I need the flat style with a washer. Does anyone know of a place to get the right lug nuts for my truck?
Yes it is the one in the avatar that failed. I think I'll be taking it to the dealer and seeing what they have to say and get it in writing, then I'' take it to the inspectors, cause I already paid them for a failed inspection, so they should sticker it then...hopefully. Yes the wheels have a taper, and yes the lug nuts seet into them well. The inspection shop said eventually the lug nut would pull through without the "correct" lug nut on it.
<a href="http://s142.photobucket.com/albums/r103/EvanNinety3/?action=view¤t=lug3.jpg" target="_blank"><img src="http://i142.photobucket.com/albums/r103/EvanNinety3/lug3.jpg" border="0" alt="Photobucket"></a>
<a href="http://s142.photobucket.com/albums/r103/EvanNinety3/?action=view¤t=lug2.jpg" target="_blank"><img src="http://i142.photobucket.com/albums/r103/EvanNinety3/lug2.jpg" border="0" alt="Photobucket"></a>
The difference between these and the ones made for aluminium rims is the ones for the aluminium rims are a little bigger, giving them more surface contact. They are chrome lugnuts, usually a little bigger as far as what size socket fits them, and they have what may appear to be a washer on them, but it's not. They're a solid lugnut, that expands a little bit bigger than the flats on the lugnut, giving it the appearence of a washer. Hope that makes sense. TJ will chime in later. Can't post a picture. All I have is a 35mm camera. I'm still in the stone age. John
