help!!! exact location of PCV on 02 4.2 - F150
I followed the hose from the valve cover to the intake assembly.
I removed the two torx screws that hold the housing to the intake.
This housing has two small diameter hoses (I read that these are to heat the PCV).
Now, I do not see the PCV valve. Is it in the housing? How is it removed?
Am I on the correct path to a successful PCV replacement on my 02 4.2?
I think you might not be looking at the PCV valve.
I remembered and old thread.....
https://www.ford-trucks.com/forums/6...pcv-valve.html
Well, on second thought, maybe you are loking at the PCV valve.
If this link works, here are some pics of replacement PCV valves.
Pcv Valve - 2002 Ford F-150 - AutoPartsWarehouse.com
Some PCV valves do have two nipples for connecting lines to, but I don't remember the 4.2 using that style.
wsbenge
09-14-2003 02:49 AM
