Starter Solenoid
A common cause for the clicking is a bad connection at the battery or a low battery.
If you want to test the solenoid, take a small wire and jump #3 to #5 in the diagram aboveMake sure the truck is in park or neutral. The solenoid should click, and the starter should turn. If it doesn't, then take a large jumper cable and jump #3 and #6 in the diagram above. If the starter will turn, then yes, I would suspect a bad solenoid.
Carmax
13
11-17-2015 08:42 AM
LloydH
08-08-2015 08:19 AM
shadowcatcher
Electrical Systems/Wiring
09-29-2003 05:04 PM
