Offroad & 4x4
4x4 on35
Old 05-03-2001, 05:02 PM
Eddie's Avatar
Eddie
Eddie is offline
4x4 on35
Old 05-22-2001, 08:10 PM
therigwelder's Avatar
therigwelder
therigwelder is offline
4x4 on35
I bought a 77 ford 4x4 with 14/35 15's when i drove home thfront end has a bad shimmy so i checked the suspension everything seemed allright except for radius arm could this cause a shimmy or should i have the tires balanced first?
where can i buy replacement rear quarter panels for same truck?
Old 05-23-2001, 08:40 AM
72f100's Avatar
72f100
72f100 is offline
4x4 on35
Did the shimmy continue the entire way home or did it smooth out after a few miles? Those are probably bias-ply tires on that thing and they tend to get flat spots in them when the sit. These normally work themselves out after a few road miles. If the truck sat fore a long time they might have permanant flat sopts in them or may take a long time to work them out. Try jacking up the truck and rotating the tire by hand. If there is a bad flat spot on the tires you should be able to see it w/ your eye as you rotate the tire, it'll look like it's wobbling alittle. If you had a spare set of tires you could bolt on and drive on this would tell you real quick if the problem is in the tires or the drivetrain.
"Like a Rock"; on the sides of roads everywhere.
Old 05-24-2001, 08:14 AM
kassonb's Avatar
kassonb
kassonb is offline
4x4 on35
For your quarter panels try http://www.browns-of-tworivers.com/ Oo:
1990 F-150 4.9l 5speed 4x4
Irish816
Offroad & 4x4
17
05-19-2010 08:08 AM
4x4x4x4
28
12-16-2002 01:54 AM
brown 4x4
12-25-2001 11:54 PM
DBUCKWILD
1997-2006 Expedition & Navigator
11-26-2001 08:32 AM
hotrodford_88
02-01-2001 11:38 AM
Quick Reply: 4x4 on35
