When were 16.5" wheels available?
#32
B7TZ-1007-A (replaced 8J-1007) .. 16 x 5.5 wheel / ID: 60880 / 1948/52 F2 / 1953/69 F250.
Be aware that FoMoCo measures wheels across the inside flanges, not across the outer lips.
Left (upper): 1957/63 catalog / Right: 1964/72 catalog / Left (lower): 1948/56 catalog. Parts catalog symbol D = F2 & F250.
#33
#34
3)
According to what I've read, when ordering the 'CamperSpecial' package, the F100 would get 15" slit-rim wheels and the F250 would get 16" split-rim wheels. Is this correct?
I have a '66 F100 Camper Special, all original, and it has 15" lock-ring wheels. Not sure if they were standard on the CS but they were definitely available.
#35
#36
A 17.5" x 5.25" wide wheel was an option on 1965 F-100s. It has the standard 5 lug x 5.5" pattern and has 1/2" of offset. It is K-H #40337 / NWRA cross reference # X-45059. No point though in cross referencing to other vehicles since Ford is the only manufacturer that supplied it on their trucks. If you find a set they will use an 8-17.5" tire that can be purchased from Coker, Universal Tire, and no doubt others.
It should accept the standard 8.092" innie hub cap. Stu
Time_Traveler
11-25-2016 01:13 PM
blue76
08-10-2016 10:02 PM
sobz
02-08-2015 11:52 AM
pwbowman
04-18-2013 10:07 PM
