Hood to cowl seal
I just looked at mine. The pieces that remain have the lip facing up.
Since mine needs replacing too, I'll ask another question.
A few of the clips that hold the seal in place are visible on mine.
Do these clips stay on the cowl while attaching the new seal,
or do they have to be removed to attach them to the new seal.
My clips don't want to come off of the cowl, do they need too?
Murph.
Edit: Oops, wrong forum, hope this info is the same.
Murph.
Clips are actually attached to the seal by two prongs that run through the seal and are then bent over. The portion of the clip that is pushed into the actual cowl metal slots is a sort of spring loaded thing. Most are quite rusty and the spring no longer works. A pair of larger pliers will remove the old clips from the cowl holes leaving the slot for the installation of a new seal which comes with new clips already attached and ready to install in the cowl's clip holes. . Oh Yes, LIP UP and pointing out to the Radiator.
kr98664
08-17-2017 11:34 AM
davidgeno123
10-10-2005 12:30 PM
