rear axle bearing/fluid level
Old 09-18-2008, 01:35 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
On anything built since probably in the 70's, use the gear oil out of the pumpkin to lube the bearings in the wheel hubs. There are a few exceptions that I have seen, but those were on old trucks. On some of the old trucks they had a grease seal that went on the wheel hub before you slid the axle shaft in the housing that would keep the gear oil from getting in the hub, and keep the grease in the hub.
Shake-N-Bake
35
12-20-2015 07:48 PM
JHoffman93
11-11-2013 07:14 PM
Piolet
04-29-2013 04:35 AM
rubrboots
2004 - 2008 F150
04-12-2010 06:55 PM
bliss1
04-05-2009 12:15 PM
Quick Reply: rear axle bearing/fluid level
