Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-16-2008, 04:00 PM
madclone's Avatar
madclone madclone is offline
madclone is starting off with a positive reputation.
2.9 hydro lifters lash adjustment
Guys, please help. Need theory. looked through this forum and found out that after assembly of heads/valvetrain initial preload of lifters should be done (+1.5 turns in after "zero"-lash). OK, no problem. The question is how adjusting screws are locked in position in rocker arm. On other engines with adjustable lash there's usualy a counter-nut on the bolt, that is also tightened and it holds the bolt in position. But in this 2.9 mother it's just a bolt in the arm. What prevents it from unscrewing? Just can't get it.
Pardon my English, I'm from Russia, but hope that I explained what I want to know )
Thanks!
  #2 (permalink)
Old 09-17-2008, 12:14 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Some of the 2.9 engines had adjustable rockers, some did not. It sounds as if yours is one of the ones that does not. In this case, there is no adjustemet and the rockers are pre-set with what is presumed to be close enough to the correct lifter preload.
And your English is excellent, I have no problem understanding what you are saying!
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-17-2008, 03:28 PM
madclone's Avatar
Comrade, are you talking about this? (pic) +
i thought if it has a screw then it has to be adjustible
PS thanks for my English
  #4 (permalink)
Old 09-17-2008, 03:46 PM
TigerDan's Avatar
1968 Ford F-250
Yes, you do have the adjustable rockers. You can turn them with a wrench, they have no locknuts but are tightly fitted to the rocker which keeps them from coming out of adjustment.
__________________
FTE Moderator
  #5 (permalink)
Old 09-18-2008, 01:00 AM
madclone's Avatar
Thanks! That's really good news. A good start of у new day
  #6 (permalink)
Old 09-18-2008, 05:48 PM
8588ranger 8588ranger is offline
8588ranger is starting off with a positive reputation.
All 2.9's have the same rocker arm set up.
__________________
90B24wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
