EGR cooler up pipe removal instructions
Old 08-26-2014, 07:54 PM
TheDuke's Avatar
TheDuke
TheDuke is offline
I managed to get it out and welded a plug into the up pipe at the EGR cooler connection . sadly I didn't read your reply until afterwards. I agree, it is such a pain to work around the turbo that it would save time and frustration to remove it. I am going to work on putting it all back together tomorrow.
My up pipe clearly won't send anything into the EGR system so I was thinking it wouldn't matter how well the cooler sealed against the up pipe. Is it possible for boost to escape via the up pipe EGR cooler connection? I am a little concerned about that area as my weld is going to prevent it from sealing perfectly.
  #62
Old 04-17-2020, 01:40 AM
Dodgecase's Avatar
Dodgecase
Dodgecase is offline
Up pipe bolt mod.
Welded a 1/4” bolt to the up pipe fasteners.
Cut bolt off to proper length. Creating a tab for the up pipe bolts. Then I used a bench grinder to grind a radius on the tabs. Don’t have to hold both ends of the fastener anymore. Up pipe install a lot nicer.
Benchwrench
03-25-2019 01:20 PM
1FastGambler
Offroad & 4x4
06-05-2014 04:03 PM
JERSEY MUD
1978 - 1996 Big Bronco
03-23-2011 12:23 PM
mudder460
11-17-2009 04:28 PM
mudder460
18
09-23-2009 07:01 PM
Quick Reply: EGR cooler up pipe removal instructions
