Cleveland or not
Cleveland or not
I was brousing a local pull-a-part lot this weekend and came across something I need help with. When I finially got the hood of a 72 Ranchero I think I saw a 351 Cleveland 4V engine. I know it was 4V because of the 4 holes in the manifold where the carberator once was. The only catch was that the manifold was set up for a "spreadbore" type carb like the Rochesters. I didn't know Ford ever produced anything like this from the factory. I did look like the factory cast iron manifold.
Was I really looking at a Cleveland? Is it worth the $131 to find out?
Numberdummy will know for sure. Wiki is many times unreliable, but if they are right:
Ford 335 engine - Wikipedia, the free encyclopedia
Could it be a 351 CJ? What is the engine code on the VIN?
That spreadbore manifold is the clue. The 4300D is a spreadbore, possibly limited to HO or CJ engines...
If it's a CJ and not split open some place, it might could be worth all of $131.
If I were you, I'd PM Numberdummy and get is opinion and see if the engine codes in that link are correct, along with the application info.
Good luck.
Good luck.
No.
No 351M's till 1975 in cars-thru 1979 (1977/82 in F100/350's, 1978/82 in Bronco's, 1980/82 in Econolines).
All were two bolt mains, all were 2V's, and all were a smogged terd of an engine with heads that cracked, usually just after the 2/24 warranty ran out.
1972 passenger cars (which includes Ranchero's) = the VIN engine code is the 5th digit: H = 351C 2V / Q = 351C 4V w/ 4 bolt mains.
D2AZ-9510-N .. 4V Carburetor-4300 Motorcraft / Application: 1972 351C 4V's used in Mustangs and Torino's.
Ranchero & Torino = same-o same-o, 1968 thru 1976.
Wiki Wiki = wrong as usual! The VIN engine code of M was not used after 1971.
Wiki Wiki = wrong again! Ford never refered to any V8 engine as a small block.
I wouldn't trust a friggen thing Wiki sez inre to Ford engines, and there's a lotta other wrong info there on tons of other subjects.
Example: They called the 330/361/391 FT engines, FE engines in another one a their flawed Ford engine entries.
My info source = 1965/72 Ford Passenger Car Parts Catalog.
The 351C/351M/400's have several other unique features, the fuel pump mounts to drivers side of the block. The bolts are at 12 and 6 o'clock, the only engine series that has fuel pump bolts in this position.
There's no timing cover, just a flat engine front cover plate.
mustang81
05-14-2012 04:51 PM
OldBlue68
10-02-2008 03:38 PM
84Maztang
06-13-2003 04:58 PM
400DownUnder
02-12-2003 11:21 AM
