Clicking noise in the steering column
Old 09-08-2008, 09:27 AM
is300wrx's Avatar
is300wrx
is300wrx is offline
I have this annoying clicking noise in the steering column. My truck is a 2005 F-150 4.6l with 39,000 miles. The sound is similar to what the coins makes when they are in the coin tray when you hit a bump. Anyone familiar with this? Is this something mechanical or is this just a loose part and should I not worry about it?
Old 09-08-2008, 04:18 PM
shorebird's Avatar
shorebird
shorebird is offline
It's hard to diagnose a noise when we don't know when it happens. Is it there when you turn the wheel? When you hit a bump? We need more info. Do you have a bunch of keys on the key ring? Take the ignition key off of the ring and drive with it alone. I have often found that a bunch of keys will make noise as they swing around.
Old 09-08-2008, 04:26 PM
is300wrx's Avatar
is300wrx
is300wrx is offline
When I hit bumps, the clicking noise occurs. It's definitely not keys or coins.
Old 09-08-2008, 05:12 PM
orange79's Avatar
orange79
orange79 is offline
My 05 clicks over bumps too and sounds like from the coulom also.
Old 09-08-2008, 06:32 PM
is300wrx's Avatar
is300wrx
is300wrx is offline
Yes and it occurs when i am turning left going over bumps more times then when I am going straight or going right.
Old 09-08-2008, 07:32 PM
great white's Avatar
great white
great white is offline
Same issue here. I have had the steering column trim pieces off and the clicking is in the internals (ie spring, retainer clip, I think). My rattle occurs when traveling over the smallest of bumps in the road, not while turning the wheel like a clock spring issue. But its reaaaaalllllllyyyyyyy annoying ......
I pulled the air bag (yes I did disconnect the battery and waited 10 minutes) but still cannot get at it. My next move will be to pull the steering wheel, this should allow me to get closer to the "noise". That leads me to my next question, sorry for hi jacking the thread, I bought a 2 jaw puller to remove the wheel but the OD of the threaded shaft on the puller is smaller than the ID of the hole in the steering shaft, of course after the steering wheel bolt is removed. I think the bolt that secures the wheel is an M8 or M10 and the OD of shaft on the 2 jaw puller in 3/8". Don't want to damage the threads on the steering shaft since they are internal threads. Any ideas? If I can get the wheel off this should expose the pieces/parts rattling around.
Old 09-08-2008, 08:58 PM
VFR_Man's Avatar
VFR_Man
VFR_Man is offline
Originally Posted by great white
Any ideas?
Put a dowel pin or other chunk of rod into the hole for the puller to push on instead of the internal thread. That or buy a set screw that matches the threads and screw it into the hole first.
Old 09-09-2008, 01:58 PM
is300wrx's Avatar
is300wrx
is300wrx is offline
Now that I recall, I remember Ford replacing "clock spring" previously and it got rid of the noise. Since that was done on warranty, and now that my warranty has expired, will they still honor that warranty repair?
Old 09-10-2008, 01:35 PM
VFR_Man's Avatar
VFR_Man
VFR_Man is offline
The new parts they installed may have a warranty of their own, 12 months maybe.
Old 09-10-2008, 05:45 PM
is300wrx's Avatar
is300wrx
is300wrx is offline
Does that usually include the labor as well? It's truly unfair to us end users to have an out of pocket labor expense due to a faulty warranted part.
Old 09-11-2008, 11:40 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
Ford parts have a 12 month 12,000 mile warranty which began when the part was installed. If that installation was done within that time frame the part should be covered, otherwise not.
Old 09-13-2010, 10:26 PM
wakenup23v's Avatar
wakenup23v
wakenup23v is offline
Thanks for this post. My 04 Excursion has been doing the same for a while. Sounds like a bunch of work and probably something I won't try on my own if I have to remove the airbag.
Old 09-14-2010, 04:44 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
My 02 has the same noise and it's coming from the clockspring area as well.
Old 09-16-2010, 03:26 PM
Sako 75's Avatar
Sako 75
Sako 75 is offline
There is a TSB on this issue. I stumbled across it and remembered seeing this thread.
TSB 05-15-1
Northernroots122
19
02-01-2024 04:49 PM
Firestix
2009 - 2014 F150
12-26-2016 08:25 PM
don123
1999 to 2016 Super Duty
12-23-2015 09:25 AM
corksil
10-08-2015 11:03 AM
Emers7mm Magnums
06-21-2011 05:40 AM
Quick Reply: Clicking noise in the steering column
