Thermostat
Thermostat
Hello
I just went to change my thermostat in my 2001 F250 V10 and bought a 195 degree. When I pulled the one out of the truck it had a 185 degree in it. According to the parts store 195 was from the factory is this true. Also wondering if I put the new 195 in if I need to have anything changed in the computer or will it just work fine...
Thanks
Thanks
I am under the understanding that fords don't like low temp thermostats. The computer can read too low coolant temps as not warming up and stay in open loop operation. I don't think the computer will notice the 10 degrees warmer, and you should have stock mechanical fans so it will not harm the cooling system.
Hello
Thanks
Thanks
JL
There's a TSB for the V10 for the coolant crossover in the front of the intake because of a false overheat.
I think they install another 'stat with it. Yup...
06-21-15***MIL ON - DTC P1285 / P1299 - 5.4L 3V / 6.8L 3V - FALSE OVERHEAT
7C3Z-8575-A - Can't figure out what it is though.
JL
Connecticut Calvin
08-11-2016 04:30 PM
n8line1978
1997-2006 Expedition & Navigator
04-03-2013 01:04 PM
thordehr
15
06-14-2010 09:10 AM
