Water in fuel sensor
Old 08-26-2008, 04:07 PM
lionsteve's Avatar
lionsteve
lionsteve is offline
Does anyone have a step by step of how to replace the water in fuel sensor? Friends 03' light keeps coming on after draining and changing both filters. Thanks in advance.
Steve
Old 08-26-2008, 09:31 PM
Tim C's Avatar
Tim C
Tim C is offline
My 03 also used to set that light even after draining the housing and replacing the filters. I was told to remove the cover (the part with the 4 lines and the drain plug, ford calls it a fuel manifold) and clean the actual sensor with carb or brake cleaner. You'll need a new gasket (from the dealer) however. Make sure you dry it out good so no carb cleaner goes thorough the injectors. I believe the sensor is in the fuel manifold/cover. I pulled mine off, sprayed it cause it was full of some brown slimy stuff, blew it dry with compressed air, and reinstalled. That fixed my water light.
You just remove the 4 lines with the fuel line disconnect tool (available at most parts stores, kind of made like scissors), unplug the 1-2 wire connectors (depending on weather yours has the fuel heater) and remove the 4 bolts from the cover. Its been my experience that the fuel doesnt drain as long if the tank has a lower fuel level.
bubblehdsts
04-18-2013 10:04 AM
Steina
10-11-2011 04:49 PM
Steve91
12-06-2002 10:08 PM
steve_
Bronco II
02-04-2002 10:02 PM
Steve_Uzi
11-20-2000 06:03 PM
Quick Reply: Water in fuel sensor
