centrifuge
Way to go Brian...................As if I don't have enough on my mind with moving my operation 13 miles south. Now you put more ideas in my head!
But.....I have a pile of new 16" gas line pipe (up to 12') that I'v been saving. This pipe is 3/4" thick, and smooth,hmmmmmm. Darn it........Now you've started it!
Try 200 tons! I don't think a GTG would work, If I even mention the "M" word all my friends suddenly have somewhere else to be...............
a centrifuge sure seems like the way to go. between dewatering, settling the glycerin, and then settling the magnesol, it takes a while to process my batches. i was thinking of going bigger and making 100 gallons each time instead of 40 since it will be the same amount of time.
what are the results like taking your batch from the processor directly to the centrifuge?
I may build a centrifuge later, but right now I'm committed to building a "electrostatic" Glycerol separator first. Since I make 100 gallons per hour, I'd like to separate the glycerol on a continuous basis. Don't be afraid to try large batches! I can process 500 gal in 5 hours, which all go into a large tank where I let it settle.
bio-d
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-18-2007 12:05 PM
goodyear
12-01-2002 09:12 AM
