Installing 08 mirrors on 01 Superduty, looking for wiring diagrams
I will be installing some 08 mirrors I just purchased on my 01 Superduty, and was hoping somebody here had a wiring diagram or information. I currently have power mirrors, but not heated. The 08 mirrors have power and are heated, but are manual extend and fold. Please let me know if anyone has some info on this, thanks!
https://www.ford-trucks.com/forums/7...ml#post6356625
here is a link to a thread i started with the same topic. I took information from the links in the 4th post and kinda figured it out.
I also got information from this post
https://www.ford-trucks.com/forums/1...-all-done.html
it was very helpful
if you have any questions just ask me..... i ran into some problems doing this but the wiring went pretty smoothly
it was very helpful
Got the mirrors on-they are great! I didn't have time to wire in the lights, but I got the power wired and ran all the wiring under the dash, just need to hook it up when I get a chance. I will try to post pics when I get a chance. Great update from the small paddle mirrors, especially when pulling the 36 footer!
Just wait till you get them hooked up. The lights looks awesome! Goodluck with the rest and glad you like them!
I got a quick question. Which light is the turn signal and which one is the parking light? I guess it dosent matter, but how does the factory have them?
Also I have different color wires to operate the mirrors. But it wasent hard to figure out.
I can not wait to install these. My drivers side is broken and is sucks trying to back up my trailer.
Thanks for the reply. I actully put them on the truck last night without wiring them. I did run into a snag. There is a little plastic tab that I had to use a hammer and break off because they would not sit flush on the door. Oh well just took me about 20min of scratching my head to figure out. I did find that post about the mirrors moving backwards. I am going to go run the wires and hook them up now. Then I will take apart the mirrors and fix the servo wires. THanks again. Mike
I just wacked it with a hammer and broke it off. Took like 2 secs.
Now I can not figure out the driver door wiring. I only have three wires coming out of the door and three going to the mirror. No matter which way I wire them up the mirror does not move. What did you do? The passenger side did just like what everybody else said. left would go right and right would go left. My truck is a 99 dont know if that matters or not.
pass work, driver not
that is strange, can you test the original mirror to make sure it is not the switch
if i recall he colors even matched up
you arent getting one of the light wires switched with the mirror control wires are you
test to see if you get the top and bottom lights to work with the wires left, if not then there is a mix up
Red-Red
Yellow-Yellow
Blue-Black/Grey spots
I am going to see if a guy I know will let me test my switch in his superduty. It worked before the mirror exploded. Thats what is driving me crazy.
Do you know if I have to take both mirrors apart and swap the wires to the motor or just the passenger side?
