Rhino or Line X??
if you are looking for a do it yourself job that is just as good, try hippo lining. its a two part system, unlike herculiner, and works better. i had an f150 that i had a rhino lining sprayed in for $450. it was a great liner, and i would recommend it, but expensive. i just got done spraying in a hippo liner in my bronco and it i am equally impressed. it only costs about $70 for the kit.
prep is the most important (and where most of the cost comes from if you are having a line-x or rhino) it takes the most time. it took me a little over 2 hours to mask off the bronco, and about 5 min to spray each coat. i work in a garage so i had access to air hoses and a spray gun. if you have the equip its worth it.
i did the LineX
https://www.ford-trucks.com/forums/4...one-today.html
and havent had a problem with it EVER!!! I have dragged motorcycles, refrigerators, etc and still like new
