Head gaskets?
Old 07-26-2008, 08:56 AM
wagntwister's Avatar
wagntwister
wagntwister is offline
Head gaskets?
I have an 04 5.4L with 96,000 on it. I just changed the oil and found that the starter is wet also the bell housing is wet. I pulled the rubber plug on the bottom of the bell housing and it's dry inside so the rear main is good. It's kinda hard to see the back of the head on the right side but it looks like it might be coming from there the left side looks like it just might be starting to leak. I need to get this fixed before the 100,000 warr. expires. I know some dealers will tell you it's normal for it to be wet so has anybody had this done with or without the dealer busting your chops? The dealer I have used in the past is decent but i'm afraid of the this is normal speach and don't worry about it then at 100k him telling me to have it done right away at my cost.
Old 07-27-2008, 12:40 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
A leak is a leak, it is not normal.
Old 07-27-2008, 08:48 AM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Yep. when I bought mine the timing chain cover was leaking and they fixed it no questions asked under warranty.
Old 08-04-2008, 01:30 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Didn't some of the V8's have oil leaks from a bad head or head gasket?
Old 08-05-2008, 10:12 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
The rear of the passenger side and the front of the driver's side are where the oil feed passages for the cylinder head are. They are very close to the edge of the head gasket,and if there are any imperfections in surface or if the engine plant missed cleanup and left debris from machining on the sealing surface near these oil passages,you'll end up with a seeping head gasket. The driver's side just seeps oil right back into the pan because it's behind the timing cover.
JL
Old 08-05-2008, 01:12 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Found it, I KNEW there was a TSB for it:
03-6-2***ENGINE - CYLINDER HEAD DECK LEAK - 4.6 AND 5.4L ENGINES - NEW "SERVICE-ONLY" GASKET AND CYLINDER HEAD KITS AVAILABILITY
Of course, this was only up to 2002, so it doesn't apply to the 2004 that the original poster owns.
wildwest2
11-04-2014 07:34 PM
Gary A.
07-20-2014 09:19 PM
reddog99
1983 - 2012 Ranger & B-Series
06-21-2012 09:24 PM
enzer2406
13
02-18-2011 01:37 PM
wagntwister
1999 to 2016 Super Duty
07-28-2008 08:31 AM
Quick Reply: Head gaskets?
