Anti-freeze waterfall
Old 02-11-2011, 02:43 PM
enzer2406
enzer2406 is offline
enzer2406 is starting off with a positive reputation.
Question Anti-freeze waterfall
So, last night my "91 F-150 started streaming antifreeze somewhere near the rear of the motor. It is a 5.0L with manual 5speed trans. It was running down my transmission bell housing but I could not see where it was originating from. It was difficult to see what was wet and what was just oil glistening. I checked my oil and didn't have water mixing, so I don't believe it is a head gasket. When I shut it off I heard the steam hissing from the right side and was obscuring my rear spark plug. Being on the right side I'm fairly certain it is not my heater core. Anybody have any insights into where it might be coming from and how to remedy it?
Old 02-11-2011, 02:46 PM
topdogcustoms
topdogcustoms is offline
topdogcustoms is starting off with a positive reputation.
freeze plug
Old 02-11-2011, 02:49 PM
enzer2406
Do you know where the plug is around there so I can look specifically?
Old 02-11-2011, 02:55 PM
Kalahnikid's Avatar
Kalahnikid
Kalahnikid is offline
Kalahnikid is starting off with a positive reputation.
Above the oil pan on the side of the block. Im not real familiar with the 5.0 but there is usually more than one.
Old 02-11-2011, 02:58 PM
88n94
88n94 is offline
88n94 is gaining momentum as a positive member of FTE.88n94 is gaining momentum as a positive member of FTE.
If you say drivers side or passenger side, everybody will understand. Right side or left side is relative to where you're standing.
Old 02-11-2011, 03:02 PM
CJM8515
CJM8515 is offline
CJM8515 is starting off with a positive reputation.
FYI: when talking about a vehicle right/left denotes if you were sitting inside the vehicle.
Old 02-11-2011, 03:05 PM
enzer2406
Sorry, driver's side rear of engine. Right side when I'm looking under the hood.
Old 02-11-2011, 03:07 PM
enzer2406
After looking some more, I am afraid it may be one of the plugs on the rear of the block. A good portion of the antifreeze was coming out of the bottom of the bell housing. I know I have to pull the trans to get to these. Does anyone know if I have to pull my flywheel too?
Old 02-11-2011, 04:02 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
Kapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to behold
There are no freeze plugs on the back of the block. I had my engine out and I can vouch for that. There are however, plugs on the backs of the heads.
Old 02-11-2011, 04:06 PM
enzer2406
Thanks, Kapusta. That saves me from a lot of anxiety about this fix. The rear of the heads won't be so bad.
Old 02-11-2011, 04:15 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
Hopefully that's all you need. My 302 was leaking from the back because a water jacket cracked from a really hard freeze. I also had water in the oil.
Good luck.
Old 02-18-2011, 12:33 PM
enzer2406
ok, so it's not my rear freeze plugs in the heads. I got ahold of a fiber scope and could see a river of antifreeze running across the top of my tranny from the middle of my engine. I still couldn't see exactly where the leak is coming from because my fuel lines wouldn't let me get the scope around them just right to see. I'm hearing a hissing sound when it is cooling off which my father thinks might be the intake gasket. I'm still not completely sure what it is but I'm going to tear down the top of my block and replace all of the gaskets in a week or two when I get time between work and classes. I really hope it didn't crack the water jacket! If it did, does that mean the block is trashed?
Thank you everyone for your helpful input.
Old 02-18-2011, 12:52 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
I wouldn't think it's a water jacket if it's running across the top of the transmission. I had water dripping from the bottom of the bell housing because of the cracked water jacket. There are two freeze plugs on the back of the upper manifold so you may want to check them. The lower manifold also has a water passage it shares with the heads at the back so that could be a source of a leak too.
Old 02-18-2011, 01:37 PM
enzer2406
I checked the line that runs between the two heads and did not see leaking coming from it on either side. Wherever it is specifically coming from is no more than an inch above the top of the bell housing. It seems to be dead center or just to the driver's side of center.
rmalottwtes30
12-21-2011 04:41 PM
Ftwofitty
1999 to 2016 Super Duty
02-18-2011 10:29 AM
Mr. Bob
12-04-2006 09:58 AM
Dennis of KC
1968-2013 Full Size Vans
11-25-2003 01:29 PM
swirk
1997-2006 Expedition & Navigator
05-03-2003 08:31 AM
Quick Reply: Anti-freeze waterfall
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
