Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
F-600 Restore
Old 07-23-2008, 01:00 PM
JQB's Avatar
JQB
JQB is offline
F-600 Restore
I am starting a restore project on 2 F-600 Trucks. One is a 1964 and the second is a 1965. My hope is to disassemble both trucks and make 1 good one out of the two of them.
I looking for resources to find information on these trucks. Does any body have any sugestions.
JQB
Old 07-25-2008, 09:12 AM
55 f350's Avatar
55 f350
55 f350 is offline
besides the guys on here haven't seen a lot of info on any of the bigun's period . but like i said the guys on here ... they are a wealth of info and ideas . oh and occassionally they keep you from getting to wild on 'em and getting in to deep ... like any one i know would do that ................ p.s i dunno bout the guys on the 61-66 forums but those of us on the 48 - 60 always as k .......... wheres the pics ??? we like pictures !!!!!!!!!!!!!
Old 02-11-2009, 11:54 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
First and Foremost, Welcome to the family of Ford Truck Enthusiast, Welcome to FTE!!
If you have not seen grm61's 63 then you are in for a treat. Posting a link to his thread just in case. I am not familiar with F600 parts, or resources but he may be able to help.
https://www.ford-trucks.com/forums/8...1963-f600.html
Further, suggest run search under 'keyword' enter F600 in the FTE search engine. See where there have been few inquiries regarding the F600 in the '48-60' forum, whether helpful or not-
https://www.ford-trucks.com/forums/s...php?do=process
Old 02-12-2009, 07:00 AM
Customcab's Avatar
Customcab
Customcab is offline
Looking forward to hearing and seeing more about your big boy toys restore. As others mention there's a wealth as knowledge on these forums.
Welcome abaord and hope you have a successful build.
Mitch
Old 12-03-2009, 12:46 PM
JQB's Avatar
JQB
JQB is offline
Removing Ignition Key switch from 65 F-600
I am trying to remove the Key switch from my 65 F-600. Whats the procedure?
Old 12-03-2009, 04:18 PM
daveengelson
Insert the key and turn to the accessory position. There's a small hole on the face of the key assembly, insert a paper clip or something simular and continue to rotate key counterclockwise and the lock mechanism should come out. You want key assembly in same position when installing.
If you don't have the key then you will likely need to take a drill and go thru the key opening and progressively work up to same dia. as lock assembly. It's unlikely you will be able to salvage the switch, I have tried it on couple of occasion and not successful, suggestion order switch and key assembly ASAP.
Old 12-03-2009, 04:27 PM
JQB's Avatar
JQB
JQB is offline
Thanks for the help
ralphcochran
Large Truck
10-19-2016 10:34 PM
C600
Large Truck
04-04-2016 10:56 AM
Notmeofficer
Ford Truck Parts for Sale
09-20-2015 09:52 PM
F-250 restorer
08-24-2013 09:33 AM
Wigglesdabum
Paint & Bodywork
12-19-2011 11:40 AM
Quick Reply: F-600 Restore
