v10 surging
Clean the MAF, change the fuel filter, and check for vacuum leaks.
Does it idle perfectly, especially when you turn the AC on and off?
A surge under light acceleration caused by an EGR valve usually means the mixture is off, or you have a vacuum leak or something throwing the mix off. If it were the EGR valve stuck open, it wouldn't idle right, I don't think.
Mass Air Flow sensor. It senses how much air is going into the motor.
It's inside the air box, after the air cleaner. If you separate the two halves of the air box, it's in the rear half. Looking at the rear half of the box, use a screwdriver in the slots to pry up the plate and the MAF is in there.
It can definitely do what you describe.
O'k, I think I shot myself in the foot some time back. When I opened the air filter housing to work on the MAF, it occured to me that the "Tornado" I installed a while back was installed right in front of the MAF. Thinking the position may have messed up the air flow over the MAF, I moved it down stream of the MAF and did a test drive. No surge at any throttle position or speed.
I went ahead and cleaned the MAF, since it hadn't been cleane in 304k miles, then did another test run of about 15 miles in town and out. No surge.
Hope this turns out to be this simple and thanks everyone!!!!!!!!!!!!1
1999, 99, accel, acceleration, accellration, cleaning, egr, f250, ford, idle, motor, surging, surrgening, truck, v10
