Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 07-21-2008, 03:44 PM
youngssvt youngssvt is offline
Garage is empty, add now
youngssvt is starting off with a positive reputation.
160 thermostat
what do u guys think about the 160 thermostat
  #2 (permalink)
Old 07-21-2008, 03:56 PM
66f25red 66f25red is offline
66f25red is starting off with a positive reputation.
It may cause operatonal problems with the engine sensors and systems, since they are calibrated to existing setup. May also reduce fuel mileage and cause accelerated internal engine wear and contribute to degradation of engine lubrication oil. Modern engines are designed to use temps of around 100c + with high pressure in the cooling system to raise boiling point of coolant. I would not do it.
__________________
66 F250 with utility body, very rusty oxidized red painted over PG&E colors. Ugh? A real restorers dream
90 F250 HD 4x4 - gone to a better place
67F250 4x2, 352 w/ 390 crank and RV cam, NP 435, 4 tube radiator, dual exhaust. Sob! sold it.
  #3 (permalink)
Old 07-21-2008, 09:14 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
The ECU wont go into cold mode and it'll cause some minor fueling issues; it may stay in open loop. Basically, the only thing you may encounter is poor fuel milage. There is no notable power gains with this on a stock motor with some bolt-ons.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #4 (permalink)
Old 08-08-2008, 10:18 PM
pkracing03's Avatar
pkracing03 pkracing03 is offline
pkracing03 is starting off with a positive reputation.
i would use a 180 if adding more boost but the stock one you wont have any problems with
  #5 (permalink)
Old 08-09-2008, 12:03 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
180 is stock on the Gen 2 Lightnings.
Quote:
What Matt said.
Basically, most highly modified guys do it as a preventive measure to help, no matter how small a diff it may be, lower the chances of detonation.
You need to have it addressed in your custom tune so it won't cause problems on cold mornings.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #6 (permalink)
Old 08-09-2008, 05:09 PM
pkracing03's Avatar
i thought its was 190 stock
Tags
160, 190, 2002, 400, 60, ford, lightning, modified, motorhome, stock, thermostat, thermostate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
