Headers? Decisions Decisions
I have a 2007 F150 and want to put new headers on it. Any input as far as a good brand goes? I am definitely going with ceramic coated. Have heard mixed opinions on each brand. Found JBA shorties for $420. Great deal. Heard that the welds tend to be rather poor. I am also replacing the exhaust and sending it out the passenger side before the rear tire. This is due to the fact that the rear axle has been hitting the existing Flowmaster exhaust out the rear. Let's just say that it is pretty LOW. Anyway, back to headers. Help?
well i dont think JBA is a bad brand. pacesetter is good too. i havent heard any bad things about pacesetter. the price is about the same for the pacesetters as well. ive seen them on ebay, ceramic and non ceramic and the shortys come with an extra pipe to make them mid tube headers. been thinking about getting them myself but i dont want to loose what gas milage im getting. if somebody tells me that the milage wont suffer then ill probaly be on the net ordering them. i want them more for noise though. im not lookin at performance increase or clearence issues. sorry to get off topic. but yes i think jba or pacesetter or edelbrock etc... go to shopheaders.com and see what they offer as well. happy hunting and good luck ya
1. fix the way your current exhaust hangs. I've had my dual exhaust catback and done some serious 4x4 stuff. never had it touch the axle (or the ground luckily)
2. why do you want headers? for the money, they aren't worth it on the mod motors. unless they are part of a complete package of gears/tuner/full exhaust/intake...and maybe a Supercharger
Thank guys! I have done the intake already. This is everything I plan on doing
1. headers
2. different exhaust
3. pulleys
4. electric cooling fan?????
5. mass airflow sensor
6. programer/ tuner
7. iridium plugs
as far as gearing goes, i am going back and forth on whether or not i should go from a 3.55 to 3.73
i have been told that all these together will produce some definite results.
1. headers
3. pulleys
6. programer/ tuner
7. iridium plugs
btw, don't waste your money with 3.73 gears. go with 4.10 or 4.30 gears. gears alone will be the biggest kick in the butt you can spend your money on. gears and a tuner will make your truck a different beast. it'll be like night and day
on
Well, actually, the 2004 and up all have "header like" exhaust manifolds. Each exhaust port has its own pipe-like tube in the manifold but they aren't up to par with true heaers. For 2007-2008 Ford made them a little better, more "header like" (similar to Toyota), but they still aren't true headers.
The headers I'm installing are long tubes as opposed to short tubes. The long tubes are definitely better for performance. Just make sure you get them cermanic coated or wrapped with header wrap to keep heat out from under the hood. Also, coupled with high flow catalytic converters it makes an even bigger difference. I'll be posting before and after dyno numbers.
NavFlyer
16
11-24-2009 06:12 AM
