Building a 89 460 EFI for my 89 F350 4x4
Old 07-16-2008, 03:47 PM
BuickBrian's Avatar
BuickBrian
BuickBrian is offline
Hey guys--I am a new guy here on this forum and need some input from anyone that has gone this route before. I have built many 429/460 performance carbureted engines in the past, so I am very familiar with the bottom end, but this is the first EFI one I have built.
Here is what I have. 1989 460 EFI engine going in my '89 F350 4x4 5-speed truck. Engine came out of an '89 F250 2-wheel drive with a 5-speed (I bought the whole truck with the 460, so I have EVERYTHING need for the swap).
Engine is ready to assembly--.030 over, stock type pistons, and I bought a cam from Comp Cams that is made to work with the factory EFI system.
I also had the rocker mounting pads on the heads machined down and drilled/tapped larger so I can put in the 7/16" studs and a set of the comp cams steel roller rockers, guide plates, and hardened pushrods.
All of that is good to go--my only question is the heads. I bought a set of heads that are the same casting as the original ones (E7TE), except that they have been machined to have 2.25" intake valves and 1.75" exhaust valves. I had a couple people tell me that this will greatly improve the performance of the engine (will use it for towing a car trailer) and will work fine with the stock computer program. Is this true? Anyone have a different experience? I also plan to put a Doug Thorley headers and pipes on it.
I also know about the transmission being different between the 351 in my truck now and the 460--already got that covered.
Old 07-17-2008, 09:22 PM
hotrodmerc's Avatar
hotrodmerc
hotrodmerc is offline
Just wondering what cam did you get? How about a part #.
Old 07-18-2008, 07:23 AM
BuickBrian's Avatar
BuickBrian
It is comp cams part number 34-255-5. The comp cams tech department recommended it saying it is designed specifically for the EFI 460 engines. The info on their website about it says: "Hydraulic-EFI Speed Density, works with stock computer. Very strong Torque, Excellent mileage, good idle quality." It costs a little more than their other cams (I guess because they don't sell many)--with lifters it was $292.
Old 07-18-2008, 09:22 AM
hotrodmerc's Avatar
hotrodmerc
Good choice of cam for a basically stock EFI motor. You should have a good strong engine with lots of useable torque for pulling a trailer.
Florida 350
35
03-17-2019 09:09 AM
96f350rcsrw460zf
59
09-12-2018 10:48 AM
StatikPulse
08-02-2012 03:41 PM
1995fordman
01-21-2012 05:27 AM
Shawn63200
09-24-2009 08:01 PM
Quick Reply: Building a 89 460 EFI for my 89 F350 4x4
