A/C heater control vacuum lines
I just purchased an 89 F-250 with a new engine.
It has the vacuum actuated a/c and heater controls.
The 'off' setting works just fine. All other settings only blow ambient air out of the defrost vents. I have checked all vacuum lines and they are fine - no leaks.
There are 5 lines.
BLUE - controls the panel vents (below glove compartment)
YELLOW and RED - seem to control the floor vents (behind radio)
WHITE - seems to control the flapper to the evaporator?? (upper left corner of engine compartment)
BLACK - what does it do??? it seems to mount to the side of the evaporator. There is a tee in the vacuum line - my real question is where should this tee lead to?? Right now it goes to the carbon canister (someone hooked these up wrong). Right now I have no source of vacuum to the heater controls or the carbon canister. Is it OK to just tee into another line off the intake manifold or throttle body.
Thanks for any help.
Floyd
There are 5 lines.
Floyd
there is a vacuum supply tank that operates your heater controls.
It is usually black in color, round and has two vacuum hoses conected to it and can be found under the hood.
there should be a lable that has vacuum routing.It should be on the core support or under the hood. Follow it for correct hose routing applaction.
have never seen heater controls work off a fuel canister!
fuel canisters are to pull fuel vapors from fuel tank and other smog controls and send back to engine to burn.
the carb. or intake is not where you should hook your heater control line into.
Find the supply tank and if you can't find it most shops would help you find it for free unless some shade tree machanic toss it.
good luck
gseeders
good luck
gseeders
The black line originates at the manifold fitting (vacuum distribution source) located on the top of the upper intake manifold. It then goes to the vacuum check valve where it splits to the vacuum canister and the other line goes to the AC/Heater Function selector. This is the source vacuum line to the switch.
Mike
93' F-150 Ext Cab 5.0L E4OD, MSD, K&N, 31x10.50's
Mike
Dummie here has no clue
I have 95 f150 5.0 4x4,, bought it knowing it needed a wee bit of TLC,, which has turned into "The money pit". A grand learning experience it has been. So,, as to my query. Small vacume accuated control over the a/c system under the hood. When I move the control by hand I hear a Flap/door inside move. The very small white/ yellowish vac line is broken and continued to desinagrate when breathed on. I have no clue where it attaches., to get vacume from Any of you kind folks have a description and maybe a pic. that would be greatly appricated.
The following users liked this post:
Received 3,108 Likes
on
Jim Lovell
12-03-2020 11:08 PM
fordtruckguy07
18
09-11-2018 09:03 AM
highoctane74
10-24-2012 11:53 PM
