Competition Diesel racing, sleds, dynos, power tuning and max performance.
idi?
Old 08-28-2009, 01:06 AM
maneyup's Avatar
maneyup
maneyup is offline
idi?
Hi I am not by any means new to ftef. I have always and will always run fords. I am strongly looking at competition pulling and dragging. I really like to keep things simple and was wondering if anyone has really built up 7.3 idi and if they are capable of high horse power or am I wipping a dead horse. Please any good feedback would be greatly appreciated.
Old 09-06-2009, 05:21 PM
Neptoess's Avatar
Neptoess
Neptoess is offline
doubt it. the problem with the idis and all of the powerstrokes before the 6.4L is the lack of ability to flow enough fuel for high hp engines. truthfully find a 2nd gen 12v cummins from a dodge. those p pumps can pump like limitless fuel. it is possible to build up an idi/powerstroke, but it costs a ton
Old 09-12-2009, 02:33 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
I would do a 6.9 IDI, they have a stronger block.
Old 09-13-2009, 01:41 AM
95_Dually's Avatar
95_Dually
95_Dually is offline
There is a couple guys with the 7.3 Powerstroke in pulling competition and they are beating the dodge's. Just my .02.
Old 09-13-2009, 10:15 PM
Neptoess's Avatar
Neptoess
Neptoess is offline
alot of those 7.3L pullers have 5x as much money in their engines as the dodge guys do in their cummins. It's awesome to have a powerstroke puller, but it's damn pricey
Old 09-23-2009, 08:52 PM
Fitzgerald_welding's Avatar
Fitzgerald_welding
Fitzgerald_welding is offline
what about injectors what is available aftermarket?
Old 09-29-2009, 08:11 PM
johnboggs21's Avatar
johnboggs21
johnboggs21 is offline
Best thing you can do for an IDI is turbo it. You can get a moose pump and moose injectors i believe. Open up the exhaust and make or buy some kind of ram air intake, and youll be in good shape.
Old 01-06-2010, 07:54 PM
charlie92/7.3l's Avatar
charlie92/7.3l
charlie92/7.3l is offline
i have 3 idi moters i thought i would try somthing one moter is prept a littel i had sleeves instaled, rods shotpeend, new balanced pistons, lowered compression to 19.5 to 1, clened up intake and exhaust ports some ideas from gas hotroding hope they werent a waist have a cat v8 injection pump trying to find injecters that can handel the fuel, building exhaust mainifold for turbo, we opened up the cups and modified them a littel turned them 20deg so the fuel will move a littel more in the cilinder. still have the stock pump on it for now runs realy good with lower compresion i thought i would lose power but i runs much beter. will have to install head studs arp befor i turbo it.any ideas
Old 01-13-2010, 10:00 PM
Farmboy1285's Avatar
Farmboy1285
Farmboy1285 is offline
No experience here sorry, but I have been tossing the idea around myself im looking for a 250 with a 6.9 to play around with but Im not to serious. Personally I really like the idea of a performance IDI just because of their simplicity reliability and the rarity.
Old 02-06-2010, 07:46 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
jimwilsonmasonry is offline
thats crazy to say because the top 4 out of 5 fastest and have the nost horsepowered powerstrokes out there are 7.3 powerstrokes
Old 02-07-2010, 12:03 AM
starmilt's Avatar
starmilt
starmilt is offline
Heres a stroke that couldn't handle the boost. lol
Old 02-10-2010, 08:58 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
Get on idi forum on here. And post similar. If your serious about this and have done that much all ready. U can push more fuel then these motors will handle with a modded DB2 pump. A stock size idi turbo is not gonna run it with that amount of fuel. Probally go to something like the first gen strokes had or larger. Lag wont be a huge issue if ur comp only.
Put a 4000 gov spring and hammer down. Studs are a must though.
Old 06-21-2010, 11:36 AM
94 smokin stroker's Avatar
94 smokin stroker
94 smokin stroker is offline
there is record of a idi think its 6.9 a guy had built that was pumpin 1200hp they can be real mean engines with some work in his case loads of work i think he owned hypermax
Old 08-21-2010, 08:21 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Yes but he was running 100 # of boost too. The block split in 3.
Old 08-25-2010, 07:06 PM
dbf74's Avatar
dbf74
dbf74 is offline
I know of a guy in northern IL with a 6.9 in a 67 half ton that would run high 8's on the strip. Has so much work done it doesn't even look like a 6.9 anymore. But with alot of money it can be done.
Quick Reply: idi?
